jasper
Member
Also ditto on my 1.6 they replaced the occupant sensor and on a seperate occasion the wiring loom - eventually it stayed fixed...
StiloJoe said:is it a major job and has it returned since u have had it done
Mike Norton said:I had the same problem when I first got my car.
There is a sensor in the passenger seat to detect when someone is sat in it to save on repair costs in an accident if you are carrying no passengers.
Initially, they said that the sensitivity was to high, so they adjusted it. The problem came back soon after so they replaced it for me. The problems not been back since.
Mike Norton
Stilo 1.6 dynamic
Had same prob but mine was on the drivers side its when i move the front seat for the passenger to get in it can knock the wiring loom under the seatcb0173 said:I have a 3 door Stilo Active and even I am having the same problems. I noticed that this happens when there is some-one sitting on the rear seat on the left hand side of the car. Taken the car to the dealer twice already. Problem was fixed but now I have to take it again since yesterday the light came on again when I had a passenger seated in the back seat.
vyore said:I have a 3dr fiat stilo active sound and recently the airbag warning light is starting to appear also with the message Aibag Failure Stop enigne at first this was intermittent but i have noticed it appears when a passenger is sitting on the passenger seat then after about 5 min into the journey it would disappear the warning now in the last few days the warning is happen constantly even when there is no passenger is there a known problem with airbag sensors on the passener Seat
Deckchair5 said:Isn't a life saving piece of safety equipment like an airbag that is unreliable through poor quality contacts and connectors comprising driver and passenger safety more? QUOTE]
Agree,but in the owners manual it states to go to dealer straight away if light comes on & its your responsibility to do that.Most Alfa owners I know stop car & get AA to tow it in & quite rightly so as what if they had a accident on way to dealers???
All airbag repairs must be carried out by DET's & approved technicians (not just a mechanic) to cut down on repeat repairs....check this has been the case if you take yours to be repaired.
