Lamps by Post - For all your lighting needs
Thread Tools
Old 17-03-2008   #1
just frank
stilosporting's Avatar
Trader Rating: 5
stilosporting has donated!
judder when accelerating
lately when accelerating full throttle at about 2k prm the engine judders and you can really feel it through the chassis. any ideas? dont think it always does it but it is getting worse?
stilosporting is offline Reply With Quote Quote
Old 17-03-2008   #2
Re: judder when accelerating
Clutch worn out/ slipping with all that extra BHP you have added.
john55 is offline Reply With Quote Quote
Old 17-03-2008   #3
just frank
Trader Rating: 5
not clutch slipping because the revs dont jump. sound as if it wants to stall is the best way i could describe it i think.
Old 17-03-2008   #4
Brain freeze
LoBsTeR's Avatar
LoBsTeR has donated!
Starving fuel? Have you replaced the air/fuel filters recently? Could be a camshaft sensor playing up. You getting any error messages?
Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet
LoBsTeR is offline Reply With Quote Quote
Old 17-03-2008   #5
is one with the dark side
Citizen Smith's Avatar
Trader Rating: 1
Citizen Smith has donated!
Possible inner driveshaft cv joint worn due to the extra torque. Is it definately engine judder or a general judder sensation ?
VW Golf GTi
"power is nothing without control"
Citizen Smith is offline Reply With Quote Quote
Old 18-03-2008   #6
just frank
Trader Rating: 5
service due in 5k. it doesnt seem to do it all the time so wouldnt think it is suspension/wheel related.
it feels like its towing when i try and floor it and judders through the chassis. im assuming its the engine as it goes away after 2.5k rpm?? also noticed today it is smoking again.
Old 18-03-2008   #7
Check OK
FiatStiloJTD's Avatar
Trader Rating: 1
FiatStiloJTD has donated!
Blue or black smoke? And is it only on hard acceleration?
2002 Stilo Dynamic 115 JTD 3 door
Grigio Steel. Full Leather, CD Changer, Fiat Alarm, Parking Sensors, De badged, Body Kit. Team JTD. Now with Roof Rails!
A Day Without a Smile is a Day Wasted!
FiatStiloJTD is offline Reply With Quote Quote
Old 20-03-2008   #8
just frank
Trader Rating: 5
black smoke. not lots but more than normal. yes only hard acceleration.
Old 20-03-2008   #9
Check OK
Trader Rating: 1
Its just unburnt fuel, i have the same problem on mine. Im not sure why its causing a judder though....
I normally notice it when i accelerate hard in the dark and notice the smoke in the cars lights from behind.
My oil level isnt droping, doing about 50mpg and its running smoothly (touch wood).
Nothing to worry about, it does it on most diesels. My old Xsara HDi (which was running on full synthetic and with only 60k miles) was doing the same. Just diesel.
It helps parking on the flat to avoid smoke on start up.
Old 24-03-2008   #10
My drive shaft spline went last Friday, with the same symtoms.
Its been in the garage for over a week and they still havent got the part.
Its going to cost about £210 to repair - an independant garage, not a dealership.
The bloke at the garage told me it is a common fault if larger wheels are fitted to the car - I have the same wheels as you.
The new part (when I get it) has been modified and is stronger.
John.
Had a Yellow Bravo. Now got a Yellow Stilo!
JohnSturman is offline Reply With Quote Quote
Old 25-03-2008   #11
I got me a user title!
mooshooh's Avatar
mooshooh has donated!
I've had he same problem for a while now, only when accelerating hard though. Mine's not a diesel though although it does have bigger wheels fitted.
mooshooh is offline Reply With Quote Quote
Old 25-03-2008   #12
popping out
dan-the-man has donated!
Quote Originally Posted by JohnSturman View Post
John.
what size wheels you got? you normally should be ok fitting the next size up (probably 18's maximum on a Stilo)
dan-the-man is offline Reply With Quote Quote
Old 25-03-2008   #13
Driver Extraordinaire
minimad99 has donated!
yeah exactly and 17's can be standard fit on stilos anyway so the extra size shouldn't make a difference. I'd understand that if it was a chavved Fiesta for example with 17's on, LOL
minimad99 is offline Reply With Quote Quote
Old 30-03-2008   #14
Orka inte
Seraph's Avatar
Trader Rating: 1
Seraph has donated!
ok, well I'm going to add to the mix here. I know that this is a diesel started thread and I don't want to hijack, but since I've had my timing done, occasionally, when driving at speed mine judders.
It's like if you were riding a pushbike and the chain were to slip, your legs go round still but the wheels slow a little... only the revs don't go up any..
it's bizarre.
HO! HO! HO!
Den som väntar på nåt gött väntar aldrig för länge
I think you'll notice when I turn this way, I'm done talking to you!
Seraph is offline Reply With Quote Quote
Old 04-04-2008   #15
just frank
Trader Rating: 5
well i thought there was no point starting a new thread.
when on the motorway doing around 60 if i just give light throttle i get judder through the steering wheel?
how would i find out if the judder is engine based or steering based?
Thread Tools
(T) clutch judder fbarcode Marea 4 18-03-2008 09:33
(T) Judder Judder Judder! poultry Bravo / Brava 8 16-05-2007 15:00
(G) judder taking up drive lancasterpete Ulysse 2 20-09-2006 09:08
(T) random powerloss when accelerating thefishdude Punto (Mk2/2b) 2 09-03-2004 20:48
(T) We want answers about the judder Joey Punto (Mk2/2b) 5 15-12-2003 21:06
