Technical Stilo ecu reset
hydie331
Hi, as anyone done an ecu reset on a 1.6 Stilo and what is involved. Also do i loose any codes like the radio imobilizer etc.
Hydie331
Hi, how to you reset the settings after an ecu reset?
Hydie331
Hello ,
Here are some codes for active diagnose on Fiat Stilo 1.6 (and other
types?)with Marelli 5NF T1 ecu :
these are the official codes as sent by the Examiner diagnostic tester-
they can be sent by ELM 323 / 327 interface once connected using Hyperterminal:
30 00 07 xx xx xx xx xx unblock immobilizer (xx = code on code card)
30 01 07 airco control ( 00= stop)
30 02 07 control of ignition coil 1 (00= stop)
30 03 07 control of ign. coil 2 (00= stop)
30 04 07 self-learning of throttle body (30 7F 00 for stop/optional)
21-7C to check > if value is 7C then S.L. is ok.
30 05 07 gasoline pump relay (00= stop)
30 06 07 RPM counter control (00= stop)
30 08 07 control for injector nr. 1 gasoline (00= stop)
30 09 07 nr. 2
30 0A 07 nr. 3
30 0B 07 nr. 4
30 0C 07 electric fan speed 1 ( 00= stop)
30 0D 07 fan speed 2
30 0E 07 heater 1 O2 (00= stop)
30 0F 07 heater 2
30 10 07 control for purge canister valve (00= stop)
30 11 07 warning lamp control (00= stop)
30 14 07 water temp. lamp control (00= stop)
30 15 07 control of ignition coil 3 (00= stop)
30 16 07 coil 4
30 7C 04 reset optional accessoires configuration
30 7D 04 reset flag for phonic wheel learning
30 7E 04 zeroing self-adaptive parameters
30 7F 00 general stop for all actuators
I hope this can be of help for Fiat Stilo owners (and maybe other
models of the Fiat Group??)
good luck, yellowstilo
today i fitted alternator went to fiat got emergency start up code but no joy there getting engine symbol paddlock symbol gowing off i check antenna thats ok car does not even turn over
