Hi
This box is from driver side fusebox for which you can gain access by opening the driver side facia with two screws. The punto which i got is 1996 N reg select 60 sx - so I presume it is the mk1 one.
can you please give me the step by step guide to gain the access of the box where this relay goes ? if you got pic of where this relay is sitting it will be gr8.
The instruction set came along meta m20 tells me the same location where the I can see the box mentioned in above pics
thanks for your help
