They're both to do with the airbag, the yellow one usually flashes on start up - it's to do with the passenger airbag and comes on permanately when you switch the airbag off. I'd hazard a guess that the accidental voltage spike has set a hard code in the airbag ECU for a voltage supply fault and just needs clearing with a scanner.
