FIAT Auto Specialist Team
Thread Tools
Old 08-03-2012   #1
Ireland
Windscreen wiper problems
I just got a 2002 Fiat Punto for my daughter. When she pushed the rear washer switch forward, it blew the fuse for both front and rear wipers. I have checked both the motor and pump and both seem to be fine. Is it possible that a faulty switch is causing this, appreciate the help.
Crazydad is offline Reply With Quote Quote
Old 08-03-2012   #2
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Windscreen wiper problems
Pop a new fuse in after you have unplugged both motors, see if it blows again, if it does it could be the switch or a wiring short.
If it doesnt its possible you have a motor problem, is the front wiper linkage in good order & both spindles free to move... these often rust solid.
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 08-03-2012   #3
Trader Rating: 5
fingers99 has donated!
And try isolating one motor at a time.
I can't remember how these are wired up. One fuse, I think, but motors are switched independently? Which would put the fault (possibly) with the rear motor?
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 08-03-2012   #4
Trader Rating: 5
M12 fund 20
Old 09-03-2012   #5
Ireland
Hi, thanks for the replies, I have tried both possible solutions and problem still there, it only happens when you push the switch forward to activate the rear washer.
Old 09-03-2012   #6
Trader Rating: 5
Locate rear washer motor (no idea where on Puntos!), pull the connector(s) off it, replace fuse, try again. If the fuse blows, you've a short between the push and the motor. Otherwise, look to the motor itself.
M12 fund 20
Thread Tools
(T) Problems with getting the windscreen wiper off of the spindle of a Punto Spoult Punto (Mk2/2b) 3 11-01-2010 20:23
(G) Help - Windscreen Wiper problems thepages975 Bravo / Brava 6 14-05-2008 09:22
(T) windscreen wiper not wiping the windscreen Donnie Darko Grande Punto 14 18-12-2006 00:21
(G) Windscreen Wiper chrisunoman Uno 3 02-08-2004 12:40
