| | Thread Tools | Search this Thread |
| | #1 |
Posts: 73 Thanks: 1 Trader Rating: 0 | Removing standard blaupunkt system I've got a fiat punto mk2 1.2 8v with a standard blaupunkt system in, I just wanted to know is it worth me taking the system out myself or getting it done from halfords for £24.99 if I buy a system there too (which I don't really want to do) Just need a decent guide on how to remove the old and insert a new one because it'd save me a bit of cash, but can anyone tell me if it's a big job or not? Note: Not done this before but i've got a good clue of what's what
__________________ ![]() |
| | Quote
| | #2 |
Posts: 2,819 Thanks: 114 Trader Rating: 0 | Re: Removing standard blaupunkt system its easy mate. it was my 1st time when i did mine too. what ya do is buy the fascia surround 1st... you can get em cheap on ebay, but better off looking for one that includes the radio aerial adapter and radio removal key.... here is what i mean: http://www.ebay.co.uk/itm/Fiat-Punto...item3cb8d5c0ca once ya got them, you use the keys to fit in the 4 holes (2 each side) and push them both in at the same time. they can be stiff, but a small jiggle and some pressure in and you should hear the radio click out. from there you just pull out the radio and disconnect the radio leads. once ya done that, it does depend on the new head unit, but basically u pop on the fascia adapter, then slot in the HU cage, connect the leads to the HU (should be self explanatory for where they go) and slot in the new HU. few points to be aware of: some head units need lead adapters, but ya can check this when in halfords and buy if needed. make sure that the cables dont fall down the slot.... wont be too fun trying to recover them from behind the dash. you may not use all of the in-car leads; the stock radio is connected by 3 leads (including radio aerial), but a lot of after market HU use only 2. and when slotting in the HU, it can be frustrating..... the leads can get caught up and stop it from slotting all the way in.... try to feed the wires back to the right hand side as you fit the HU, there isnt much room, but it does fit. its an act of common sense for the most part to just take your time and dont panic. £25 is a lot of money for something that would take a novice 30 mins start to finish. only you can decide if your confident enough to do it tho. |
| | Quote
| | #3 | ||
Posts: 10,406 Thanks: 533 Trader Rating: 0 | Re: Removing standard blaupunkt system The cabling adaptor is important because Fiat wiring is not the same as all other makes and you can end up with the stereo never actually turning off which flattens the car battery. Will the Halfords guy (or any other fast fit outfit) know that? Maybe; but we have so many battery problems posted that end up being badly wired stereos we have to wonder.
| | Quote
| | #4 | ||
Posts: 4,153 Thanks: 163 Trader Rating: 0 | Re: Removing standard blaupunkt system i bought the proper iso lead allegedly off a good internet shop that said it would work it didnt i had to make one up/might have well done that in the first place but it wasnt my car or new stereo halfords want fortunes for face plates last time i was in there i suggest a scrappy, theres usually a plate in there for $2 plus the converter plug for the aerial will most likely be there too loads a money saved see
| | Quote
| | #5 |
Posts: 73 Thanks: 1 Trader Rating: 0 | Re: Removing standard blaupunkt system Cheers for the info, I'm most likely going to find a cheap HU on the internet and fit it, so I'll try to keep away from halfords fitting, unless it's urgent. Also, when you say 'Stereo never turning off' do you mean when it still stays on when the engine is switched off? My current punto has this problem and you have to turn it off yourself, I'm not too fussed about this because I automatically turn the system off now i'm used to it so I can't see me leaving it on. If not, how would I make sure it doesn't constantly stay on and is it best to go for a system with the 3 leads to make the wiring process easier? I'm leaning towards the Mutant bluetooth system, can anyone suggest anything else decent (and not too expensive) possibly bluetooth because the Mutant BT system is the only decent I can find!
| | Quote
| | #6 |
Posts: 2,819 Thanks: 114 Trader Rating: 0 | Re: Removing standard blaupunkt system some HU can draw power even when off. fiat wiring is backwards so the power remains separate from the ignition and can be turned on/off without the key. here is a guide which can sort it: http://www.fiatforum.com/punto-guide...red-wires.html |
| | Quote
| | #7 |
Posts: 73 Thanks: 1 Trader Rating: 0 | Re: Removing standard blaupunkt system Oh I see, i've got my eye on the kenwood kdc bt30 also, but i'm not sure if its compatible with punto mk2 and i'm going to try and fit it myself if it fits, any pointers too look out for not already mentioned?
__________________ ![]() Last edited by PuntoActiveS; 03-09-2011 at 02:45. |
| | Quote
| | #8 |
Posts: 8,111 Thanks: 323 Trader Rating: 0 | Re: Removing standard blaupunkt system My Stereo is always live, never had a problem However i think i am running a cable set from the Rip-speed unit i have (it was cheap at the time tho) Ziggy
__________________ |
| | Quote
| | #9 |
Posts: 73 Thanks: 1 Trader Rating: 0 | Re: Removing standard blaupunkt system Bought the kenwood kdc bt30 from a mate, just wondering if there is any other pointers I should know? I looked at the guide http://www.fiatforum.com/punto-guide...red-wires.html This doesn't explain as accurate as possible, just seeing if anyone can give some easier advice to avoid the system remaining on when the ignition is off! Cheers
| | Quote
| | #10 |
| | Quote
| | #11 |
Posts: 73 Thanks: 1 Trader Rating: 0 | Re: Removing standard blaupunkt system ...
| | Quote
| | #12 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 | Re: Removing standard blaupunkt system Right, ive just installed a new cd player to replace the ****ty tape player my girlf has been using for the last 5 years, can you understand the frustration of borrowing her car!. i ripped out the tap unit at xmas and have only just figured out how to get the cd player working without draining the battery. (i dead battery later )I think she has a mk2 punto.. but im no expert on this. Heres how i did it, I used a multimeter to find out there was no fookin ignition feed on the hookup. so i took a feed of the cig light and patched it into my the ignition pin on my stereo. my/her stereo had a nice picture on the back showing my what wires did what. I scotch locked a wire from the cig lighter socket. I removed it via a guide on this website (theres big list of guides somewere) try this punto-guides/129715-punto-mk2-centre-console-removal-bulb-replacement-3.html Basically there are 4 four allen key screws that need removing, two either side of the air vents down in the foot well, and two in the little tray thing under the heater controls. that done, i gave it a bit a tug to get it past the gear stick and the panel fell off. Theres a little catch on the plug for the lighter that you press and the wire pops out. i tested them all (using the black ground on the headunit lead) and found the middle wire as the ignition live wire, so i scotch locked another wire to it, fed it through the dash and scotch locked it to the ignition feed into the stereo. And voila! my first successful car hack! i was new to the old scotch locks, so i bought ten of the fookers for 2 squid off ebay, and i now fooken love them!! now my problem (and maybe yours) is to get the little door speakers (the other side of the wing mirrors) linked up?? maybe more scotch locking is required.
| | Quote
| | #13 |
Posts: 73 Thanks: 1 Trader Rating: 0 | Re: Removing standard blaupunkt system Thanks for the tips, after PM'ing you I realised it may be easier to do this way: http://www.fiatforum.com/punto-guide...red-wires.html Just need a bit more help on the above, do both the red and green wires need to be switched on both of ISO connectors? Or does the greeny blue wire need to be left out? Or does the greeny blue wire need to be switched with red and problem solved? Can anyone confirm any of the above!
__________________ ![]() Last edited by PuntoActiveS; 15-09-2011 at 03:24. |
| | Quote
| | #14 |
Posts: 73 Thanks: 1 Trader Rating: 0 | Re: Removing standard blaupunkt system I'm also guessing the stereo on an 04 punto would be the same as the 51 red punto in the guide?
| | Quote
| | #15 |
Posts: 2,819 Thanks: 114 Trader Rating: 0 | Re: Removing standard blaupunkt system ive not done this myself... i tryed but couldnt get the damn clip out of the iso socket and didnt wanna break it, but from what i understand, u are just moving the one wire from the HU loom socket into a different pin location. the guide only mentions the moving of that one wire. check against the guide the wire colours/locations on ur HU... should be pretty much the same really and then move that pin if u can pop it out. |
| | Quote
| | GPdanny | Grande Punto | 8 | 09-06-2011 21:11 |
| | wynne | Punto (Mk2/2b) | 13 | 15-03-2011 08:12 |
| Standard Blaupunkt Tape Player swap for Standard Blaupunkt CD Player Problem | rclapton | I.C.E | 3 | 18-03-2007 21:14 |
| | Alfie | Punto (Mk2/2b) | 2 | 06-03-2006 20:08 |
