Thread Tools
Old 29-10-2009   #1
what causes a thermostat to fail and how do i check a water pump is working????
is there a way of checking the water pump operation?, ave changed the thermostat as my car was blowing cold air and now it heats up no problem.
reason for changing thermostat was a slight milky residue in my oil cap, apart from it not working either lol and understand that it is the most common failing of a head gasket.
car did give off a skrech when i had replaced the thermostat, i assume this was the water pump getting rid of the air in the system?
car heats up fine and sits and 1/4 most of the time and doesnt go above half.
what causes a thermostat to fail ?.
i am doing alot of work to this car, and im about to change the coils and ht leads as i have that annoying power loss to.
thanx for reading
chaos123007 is offline Reply With Quote Quote
Old 29-10-2009   #2
Trader Rating: 10
dave has donated!
Re: what causes a thermostat to fail and how do i check a water pump is working????
Quote Originally Posted by chaos123007 View Post
i
old age.
did you bleed system like it says in the guides? gauge should sit at half way all the time
What is right is not always popular and what is popular is not always right.
Albert Einstein.
Old 29-10-2009   #3
Mine is in the middle of the gauge sometimes and only 1/4 at others. So the thermostat is on the way out. About 35 from Shop4Parts (plus postage) or best part of 50 from a Fiat dealer.
WhiteSei is offline Reply With Quote Quote
Old 29-10-2009   #4
Bugs Beware!!
Noddy's Avatar
Noddy has donated!
Add Like Mad Champion, Badger Race Champion, Bumper Golf Champion, Super Mario Mushroom Champion, Mili & Tary HG Champion, Valentine Surprizes Champion
After flushing the rad, fitting new water pump & thermostat and having the head skimmed, mine now sits at 1/4 and doesnt seem to go above half.
Would have thought if the thermostat was on its way out it wouldnt open causing the car to run hot not the other way round???
Noddy is offline Reply With Quote Quote
Old 29-10-2009   #5
Trader Rating: 10
dave has donated!
when they are on the way out they normally open only a tiny bit and tempature sits at a quater instead of half
Albert Einstein.
Old 30-10-2009   #6
Bugs Beware!!
Noddy's Avatar
Noddy has donated!
But mine is new and sit at 1/4? Surley if they dont open then the flow to the rad is reduced and the engine would run hotter?
Old 30-10-2009   #7
Trader Rating: 10
dave has donated!
if yours is new then you have another problem. the normal temperature is half way
Albert Einstein.
Old 30-10-2009   #8
Bugs Beware!!
Noddy's Avatar
Noddy has donated!
Ok then a real test for your knowlege then:
Apart from the thermostat what else would cause the car to run cold???
Old 30-10-2009   #9
loads of responses, i replaced my thermostat and it sits and 1/4 all the time, seems to be fine now, changed air filter to dnd cleaned throttle body, it was manky, found a few splits in the air hose so i patched it up.
got some milky residue in my oil cap, dummo whats causing it, its not the head gasket as the car runs fine and doesnt over heat
Old 30-10-2009   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
The gauge is only a gauge, not an instrument.
It could be the sender is out of spec.
Pop a meter on it to check.
SPD
Old 30-10-2009   #11
Trader Rating: 10
dave has donated!
Quote Originally Posted by Spentona View Post
air lock
crud in the system
sensor
or the gauge its self
Albert Einstein.
Thread Tools
(T) fan or thermostat not working???? PuntoAlan Punto (Mk2/2b) 8 22-11-2009 23:14
(G) Heater Blowing cold Air ....Water Pump or thermostat...please help i'm confused Bigbadjohnxx Punto (Mk2/2b) 8 08-01-2009 17:45
(T) thermostat or water impeller? loui666 Punto (Mk1) 5 29-05-2006 21:15
(T) Punto55SX,Water leaking from around thermostat casing davethedrummer Punto (Mk1) 3 24-01-2005 23:34
(T) Marea 20v thermostat, steering pump, cams jbackg Marea 5 29-12-2004 21:20
