Hi, I have a 56-plate Panda 1.3 Multijet which, apart from the occasional clutch slip, has covered over 80,000 trouble-free miles.....until recently, that is!
I used to drive the car everyday but for the past several months I've commuted by motorbike and the car has spent much of it's life on the driveway, being used only at weekends.
Over a period of weeks, I experienced some starting problems, particularly after a spell of rain and more so (it seemed) if the car had been parked facing (slightly) uphill on the driveway.
Recently, the car was unused for a period of 2-3 weeks in April when the weather was really wet. On trying to start the car, it turned briefly and then stopped, almost as though the starter had jammed on the starting ring.
It was trailered to the local Fiat sub-agents who said that the sump was full of water and that a con-rod had most likely bent when trying to turn the engine over whilst water was in one or more cyclinders.
There's a posting on Honest Jon, suggesting that this is a known problem and that in periods of heavy rainfall, water gets through the air-filter and into the engine.
I should add that there had been no loss of water from the cooling system.
I wondered if anyone else on the forum has experienced this problem.
The cost of a new (or reconditioned) engine.....don't even go there!
