ExBrava2012
- Feb 4, 2012
- 11
- 2
Hi, I'm looking for advice on this problem. I can drive slowly on a flat road without pressing accelerator pedal for about 3-400 metres in 2nd gear and probably in 3rd. Does this seem to be the result of a too rich fuel/air mix or perhaps too fast idle? Would new plugs and air filter be a possible solution. (The engine is warm when this occurs)
As a result of this problem I believe is undue wear on the brake pads is caused in addition to the extra fuel used.
The garage says there isn't a problem.
Thanks for any help.
