randysbits
Recently fitted some Koni sport adjustable dampers, and Eibach springs, the improvement in ride quality is remarkable. The main reason for fitting this set up was to, rid the car of the po-going effect you get a per standard 100HP, and i can truly say this has gone now, completely !!
Despite what some say as over-damped, no, i don't buy that, the fact remains that Fiat fitted perfectly good springs for this particular model but, did not do a good job to match with dampers that were up to the job of the springs, hence the springs working harder giving the 100HP's po-going character
Some pics to show what i did with the rear bump stops :
Seeing as one had already perished / cracked, i removed this portion due to the drop in ride height that the Eibachs would give, bare in mind though, they were almost touching with the standard ride height
With the top part of the polyurethane too loose for a good fit, i opened up a stainless steel washer into a horseshoe shape to slip over the top mounting, to give a tighter fit against the underside of the body.
Difference between old springs to the new progressive wound Eibach :
Rear Koni with proper 360 degree bush, not a designed to fail bush :
Then by applying this spray wax to keep corrosion at bay, i gave every new component a coating of of the stuff, goes a long way and protects your investment well.
Picture of complete rear end fitted before the fronts were done
Annoyingly, i forgot to measure the ride height on the rear before i fitted the new springs but, before i did the fronts, the height has come down by a genuine 20mm from standard, i was surprised it was as much as this, looks so much better for it, wouldn't want it any lower though.
So as it stands, the car sits nice and level, after the geometry was set to 1 degree negative camber (with camber bolts), and the toe set to parallel, it has totally transformed the car and steering is sharper as a result, better weighted on "Sport" mode, excellent feedback whereas before, was a little vague, every corner now is something to look forward to as it handles so well and corners pretty flat, i am falling out the seat on right turns not the best hugging seats but i have always said that so, Recaros will be fitted next
Currently, the dampers are on the minimum setting and is perfectly except-able although, i will have a tweek on the shocks to see how much it will improve the ride as, in the past with other vehicles, i have ended up turning them up to maximum for the best ride, this is speed dependant and will be firmer at slower speeds (around town etc).#
In my absolute honest opinion, the way this car irons out bumps and shallow pot holes now is how it should have been (at least) from factory.
