danharwood
- Jan 10, 2010
- 24
- 11
Hi
I've got an 07 100HP 23k on the clock. Last Weds I noticed that the clutch pedal was a bit sticky as I got to work and then again when I left work, but then appeared to be fine for the rest of the journey home.
On the Thurs set off for work no problems with the pedal. Then about halfway there the pedal became sticky again (as in it didn't want to return to the normal position after being depressed) and it became difficult to get into gear, when I finally got it into a gear (2nd) even with the clutch pedal fully depressed the car was trying to drive forwards as if the clutch was engaged, as I was in a queue of traffic I got it back into neutral but it then refused to go into any gear and the RAC towed it home where it has remained ever since.
I was just wondering if anyone else has had anything similar happen or has had any other clutch problems or from the description above might be able to narrow the problem down further than 'the clutch' as I'm planning to get in touch with Fiat about it, yes I know it's out of warranty now but 23k on the clock with full dealer s/history somethings not quite right there.
Dan
Dan
