Resurrecting this thread again !
15 months on and the car at times seems under powered, no matter what you do it just seems 20hp down on power, and its not got a lot to start with !
Then the dreaded EML came on again !!
Diagnostic read P1220, only one number different to the original ecu fault code. Clearing the code did nothing, just reappeared on the next engine start.
Anyway tonight i thought i'd have a play around with ecu connectors, earth points etc. I removed the ecu earth strap from the ecu plate to the car body inner wing, cleaned all the contact points with emery and put it back together. Removed ecu connectors and remade. Did same with the three connectors around the throttle body area (under air intake).
To my surprise the EML went out on the next engine start - whether its good fortune i dunno but its one less thing to worry about overnight.
Other than that the car passed its MOT again recently, but only after yet another wishbone replacement (rear bush gone AGAIN), and a leaking damper on front offside. The other lower wishbone bush is starting to look on its way out (only 2 years old), and the drop links bushes are also starting to crack (again less than 2yrs since replaced).
Good news is the exhaust and battery are still original (now 7yrs old, 55k miles) although the exhaust box is down to its inner skin, the outer having corroded away and fallen off, taken off by me !
Starting to get to the time to chuck this in for something newer, and sadly whilst the bodywork and interior are unmarked, the thought of another Fiat with potential electrical issues puts me off buying another, even with 61 platers available for £6-7k new.
Next car will probably be of German technology, either in the form of a 1-2yr old Skoda Fabia/Roomster or a 2-3yr old Merc A Class.
