Well it's that time of year where screen wash is a neccessity and you're forever filling up the bottle. Well I used mine for probably the 2nd time since owning the car back in September, usually wash it every week so haven't needed to use them. Anyway, i've got to say i'm really disappointed. At first I thought "Cool, 6 jets of water!" but after around the third squirt it turned into a dribble. Upon further investigation the little plastic cylinder that houses the 3 holes for the jets had fallen out of the side of the main body of the washer jet and luckily was lying on top of the scuttle panel (If you look at where you stick the screwdriver for washer adjustment, that had literally fallen out of the side). I re-inserted only to find (parked up) that each time the squirters are operated, the little things slide out bit by bit under the pressure of the water.
Has anybody else found this?
I am intending going to the dealers next week while off work and getting them to fit 2 new ones (Not that that will solve much) and in the mean time I am going to look at fitting a different washer from a different car.
