Hi all. Fiat scudo o4 jtd was going into limp mode going up hills. Got it tested two fault codes
P0100 air flow meter and p1112 diesel pressure control. Pressure higher than commanded by the control unit. I replaced the air flow meter and the mechanic told me it was a new pump in the car so I was wandering what else I should look at regarding the p1112 code as the eml is still coming on. Thanks
