Hi all,
the workhorse GP has had a niggling fault since I bought the car, which I think I'm narrowing down now, however my knowledge of the electrical system in these cars is limited, so I'm hoping someone here can point me in a direction to look in.
Firstly a brief explanation of where I am at. I bought the car last November, it had a busted light bulb warning light on the dash. I went through and replaced both rear number plate lights, OS rear side light, NS front sidelight, and the dash warning was gone. Result I thought.......it went through and passed MOT.
Started using the car as a daily and noticed that sometimes the light warning on the dash would come on then go off, so I started to pay attention to try and see if there was a sequence and it appeared to show it self mostly when either lights are on and I indicate left or right at the same time, or brakes are on and I indicate left or right. As usual checked all bulbs again and all is good there.
A friend recently said to me, check your lights with everything turned on, hazards, lights, fogs, etc. it likely to be an earth problem. I did and confirmed the rear lights were doing the disco (this is to say when the indicator is on the other lights will dim in response to the indicator coming on, then return during off........you get the idea).
So yesterday I took both rear light clusters off, looked at the contacts, brushed what I could with a small wire brush then refitted.
I then went into the engine bay and completely removed the negative terminal from the battery, followed the wire down, disconnected from the chassis leg inner, then from the gearbox front. Took the wire aside and brushed all terminals to a shine, then the chassis/gearbox mounting points too. Refitted and greased over the bolts/nuts where appropriate.
I also noticed a ground point just above the ECU (located on top of the opposite side chassis leg/OS) that was coming from a T-piece of the wiring loom. Took that off and scrubbed the terminal and the chassis point then refitted and greased over.
Done a test with all lights blazing and.........
1. The OS rear is now good.
2. The NS rear is the same if not a tiny bit worse.
In summary I did 3 ground points in the engine compartment and cleaned the light cluster contacts and connectors.
Are there any other wiring grounding points in the GP that I should be looking for? I couldn't find anymore inside the cabin under carpets or in the engine bay area.
The car is a 2007 1.3Mjet 75HP 5 door Manual.
I would appreciate any pointers on the wiring of the GP which may lead me to an area I have missed out. I already looked at the guide on the 1.2 engines but the ground points in the engine compartment are in different places to the mjet.
Humour
P.S. other than that annoyance, after I changed the clutch and cleaned up the flywheel from years of clutch dust collecting in there, the car has been a peach and a joy to drive (slowly) lol.... it is a tad pedestrian but I'm almost used to it now.
Humour
