Im looking at some mtec front and rear discs and the website is saying fronts diameter measure 284 mm and rears are 264 mm. Does that sound about right to you mate?
If you are looking at Mtec ones they are ok but not as good quality as EBC etc.
I had drilled discs on the front of mine, they look like standard ventilated discs which Mtec have drilled holes in rather than them being cast with holes like brembo etc.
The holes are also pretty huge compared to higher quality drilled discs and fill up with brake dust quickly and if you dont clean them out all the time it will start to score the discs.
Id go for EBC turbo
http://www.ebcbrakesdirect.com/Sorry to jump in but we're is the best place to buy ebc discs I drive 1.9 mjet
One more question about brakes, opinions wanted actually.
If you put drilled/grooved/dimpled discs of same size as oem on your car, would you inform your insurance?
