Hi guys, new member here though I have referenced the forums a number of times in the past as my delightful '07 Grande Punto 1.2 has had it's fair share of issues in the past.
The latest issue that is troubling me at the moment is the worrying amount of time it seems to spend with it's Engine Management Light on. Sometimes it is only briefly, and at other times it can stick around for a day or two before turning off again. It seems to coincide with the engine temp dial not working.
Yesterday the Engine Warning beeped and I noticed that the dial didn't move throughout the 10 minute drive to work. When it has done this in the past, by the time I've gone to drive home the dial has worked but the light has remained on for a few drives more. This morning the temp dial is still not moving and the engine light remains on. Any suggestions as to why the Temperature is stuck on cold?! And, perhaps more importantly, what I can do to fix it?
I've had everything from the broken breather pipe, to the door that won't open from the inside, to the reluctant starting in the damp and under-revving when cold and wet! Can't wait to get shot of the orange b*****d!!
