Hello guys,
I'm looking for some help regarding my girlfriends Fiat Grande Punto 1.2 from 2006.
The reason being that the engine light is on periodically, sometimes it flashes while driving and other times its constant for an amount of time.
My dad had a friend run diagnostic with a bosch tester, where it indicated too high temperature in the combustion chamber. I've since then swapped thermostat, water pump, air filter, oil, oilfilter, ignition coils, spark plugs, timing belt, V-belt and ignition cables. The light remains the same.
I sadly do not remember the error code and i know that is troublesome in regards to pinpointing the error, but maybe some of you have some experience as to what it might be? Maybe it has some common faults - such as the map sensor (i've seen some videos on this)?
