Apologies on both my first post on the forum being a call for help and for for adding another post to this topic; the previous ones hadn't seemed to give any solutions.
Problems started around 2 weeks ago when during a very frosty evening the headlights seemed a bit too bright when starting the car. They seemed to flicker a bit, and after fiddling with the high/low beam stick, confirmed that the full beam lights were intermittently stuck on. During the 30 minute ride home they were sporadically flicking on and off involuntarily.
The next day the problem went away and shortly after one of the dipped beam filaments blew. I assumed it was just a foible. Both Main/Dipped beam, and sidelights were replaced (One sidelight had gone a week before)
Last night, on long drive back down the motorway, the problem started again (With new bulbs). All had been fine for the 90 minutes drive up that afternoon, but on the return journey the full beam stayed stuck on from the moment I turned the key, apart from a few periods of respite when they reverted back to dipped beam, despite re-staring the engine a few times.
I've had a little poke this afternoon and confirmed the following:
- 'Wand' still works, in that turning the full beam on and off turns the blue indicator LED on correctly - but no regular correlation to the actual lights dipping. If I flick it on and off several times, occasionally it actually turns the lights off,, but usually just makes them flicker for a millisecond each actuation.
- Under-bonnet fuse box appears dry (No obvious sign of condensation or dampness inside
- Relay spade terminals appear clean and non-corroded
- Relay 'sockets' on the fuse board look in fair condition
- Having switched all the similar relays in the box around the problem persists.
- Hasn't reverted back to normal after disconnecting the battery for 10 minutes, or leaving the car for 24 hours.
- Lights turn off with both wand set to side-lights or no ights, and with engine turned off
- Follow me home seems to work OK, albeit with full beam.
Any suggestions on solutions would be great. really don't want the expense of taking it to a garage to pay for a bunch of diagnostics, especially at this time of year, or even confirmation of the relay number corresponding relay for high-beam for a 1.2 Active (2007) as I cant find it on the user manual or italian service manual, just fuses.
Thanks!
Thanks!
