Yeah cool thanks
Spoke to tony at t4p who mapped my car and my car will be fine to use the actuator with stiffer springs and he said a safe level to take it up to is 1.2 bar. Wheres the cheapest place to buy the stiffer springs from? Found the actuator for £100
yeah wasn't too sure if you could get them anywhere else cheaper, what spring you got in at the moment?
Does this actuator fit the VL 37 turbo?
Have you had the car mapped? i forgot lol?
What is the boost pressure set to - if you fit the stiffer spring and the boost pressure is set below the yellow spring level it will overboost and instantly cut the power and go into limp mode
Yes Rich his car is mapped
Jack mines got the stiffer spring in (can't remember the colour now, yellow?) and it boosts to around 24psi
