lambontheflag
- Feb 11, 2011
- 93
- 20
Greetings!
Represent!
I am so happy to have find fiatforum.com , I aim to donate when I can afford it to give thanks!
I am 24 & I finally passed my driving test last wednesday!
My Grandma kindly donated me her Cinquecento 899i it is going to be 17 years old in March! I am absolutely in love with this car I can't stop looking at it and I wash and polish it every single day I can!
I have never been into hot hatches but since replacing the passenger side mirror myself I felt quite satisfied and I am investigating the possibilities of various sensible mods that are possible. Are there any mods which are possible to reduce the cost of insurance? such as anti roll bar? Rear disc brake conversion? PSI Monitor?
I am totally new at all this and I don't want to bombard you all with death by 1000 threads so I'm going to try my hardest to post all the questions I have here & now and hopefully be able to get them out of the way..
firstly (I used to be a tyre fitter) the car has been standing for a long time the tyres are cracked and warped and when I went to check my psi this evening I noticed on one of the wheels that the person who dealt with it had stuck the valve through one of the smaller hubcap holes making it very fiddly, I went to wrench the hubcap off in the normal way but it wouldnt come away as if it was attached at the centre, my freind ventured that there is a screw under a cover holding the hubcap in the centre? , is this likely to be correct? I am all for trial and error but really don't want to mistake as I love the car so dearly..
second the handbrake has to be yanked all the way up to engage slightly, local 'reputable' garage when I ask them to tighten the bolt under the handle said it would be that the handbrake had seized at the rear shoes and wanted £60 labour to fix this!?!? The guy told me it is an endemic problem with 95' Fiat Cinquecento and guaranteed me it will need sorting every year! This is not my kind of Guarantee! Can you verify the accuracy of this information I've been given? I tried to get under the car to look at it myself today but my head is way too big.. without a ramp or a pit.
thirdly the car makes a strange creaky noise when it takes a heavy load in the rear I am concerned that it has something to do with play in the rubber bushings or worse but local garage told me it's my exhaust? (wtf) What are your ideas on the possible causes for this noises? (both sides)
fourth the car seems to run cooler with more fuel in it ? Or is this my imagination? Should I be using Paraflu?
five - the gearbox is a little sticky it 'clicks into third and fourth just at the last part it seems to have improved with use but is this something I could imrove with a clutch kit or am I likely to be looking at a new GB at some stage?
6> The car has only 20000miles on it, my brother reckons it is good for 150000 but I am hoping it will go for much much longer.. How far is the limit for the Fiat Cinquecento 1995 899i?
7 - My left hand side speaker (original) is defunct, I unscrewed the cover to take a peek and there is a slight hole in that speaker, for whatever reason? I wish to replace the original speakers and maintain the original covers on new speakers so I am wondering have you had any experience of this if it is possible?
8 - Having washed my car regularly I have noticed moisture in the boot that is obviously from my washing (handwash - no hose) Is this something that can be remedied by replacing the boot seals? Also when I wash the car and spend ages making it pristine it is a bit annoying when i put my sparkly clean window down and it comes up covered in moisture out the door? Is this something that I can fix as well? I have never noticed something like this on any other car, but then maybe I have lived a sheltered life...
9 - There is no aerial for radio on the roof, I am fine with this but would you suggest any stylistic replacement particularly?or is there a way to remove the place where the aerial wants to screw in and have a blank roof?
10 - would you recommend synthetic motor oil over mineral for this model of car will that make her go for longer?
11 - If I put 15" alloys on will I be able to replace the metering unit to make the speedo accurate again?
12 - how far is it possible to mod the interior, are there laws in place about how fireproof stuff has to be?
13 - I would like to fit an alarm and immobiliser and central electronic locking so it goes chiwpschwip! Have you any experience of this and how much is it likely to cost?
14: how do i take the badges off the boot and do I risk damaging my pristineish paintwork irrevocably in attempting to do so?
Thankyou so much for reading my essay (sorry got giddy) and having me here I do dearly hope you can help me find answers to my questions
Many Thanks, and Best Wishes lambontheflag , here's wishing all fiatforum members Good Luck, Good Health & Happiness always
Represent!
