sean421992
does anyone know the problem? when i brake my back brakes lock on and the front ones dont.
thanks
thanks
i had this issue with my back brakes. as far as i'm aware. cinquecento's do not have a brake bias valve as it's all controlled from the master brake cylinder. i found that my rear drums were slightly warped which caused them to lock. i did grind them with an angle grinder as a temp fix to make them more round. which worked but eventually changed for a newer set for MOT time.
