Hi all, Ive come across a problem this evening whilst working on my 600 solving an oil leak.
Oil Leak.
Basically, i did an oil and filter change 3 weeks ago and changed the rocker gasket at the same time. Since then, ive gone through about 7 litres of oil as its losing it almost as fast as i put it in(not that fast but once ive driven around, it loses a lot).
The oil is all over the altenator, alt belt, both cam and cam belt and generally all over the place in that area of the engine.
The rocker is sealed tight but we stripped it down again today to look for the possible leak and replaced it once again.
I have spent this afternoon cleaning the all back that has been sprayed everywhere by the belts
Can anyone advise as to what it could possibly be with this vague description? Oil pump maybe(not quite sure what this looks like tbh)?
I cant see it being the head gasket personally from what i have seen this afternoon but its a possbility i suppose.
Any idea from experience or knowledge is welcomely received.
Water Leak
I have spent this afternoon degreasing and cleaning the engine back where the oil and dirt has settled from what looks like oil sprayed everywhere by it hitting the belts.
There is a round cap on the side of the head above the flywheel and beneath the cam. Whilst removing all the dirt from this area it start pouring water/coolant from a small hole in it. I am pretty sure there shouldnt be a hole in this.
I think there may have been a build up of dirt covering it, preventing it from leaking previously but after cleaning the oil and dirt back, this hole has now basically left my car unusable as it wont hold water, just leaks it out.
Can anyone advise as to what this part is that has the hole in it and if it is easy to replace, im pretty hands on with cars and do most work myself but am not totally clued up.
I have uploaded a video to youtube of the water leak. Excuse the sideways view, my phone being a bitch. And my heavy breathing, it was cold lol.
I will post vid in next post as it says i havent posted enough.
I would be grateful for any advice on this matter so that i can get it rectified asap. If anyone needs anymore info about the issue to help resolve it, please let me know as i may have been a bit vague here.
Oil Leak.
Water Leak
