Thread Tools
Old 17-08-2007   #1
Another fault!!!
After spending 300 I didn't want to spend on my little Sei sporting last month it has been running like a dream!
BUT...
Now the brakes completely failed whilst driving on the M25, lucky the road wasn't busy and I managed to use the Handbrake to come to a halt!
Fiat have told me that it is a 500 job as the brake pipes have corroded and a few other bits too, I kinda lost focus after he told me the price so can't remember what exactly is wrong! oh, he said the handbrake is seized too. Seems very expensive to me, especially as the car is only worth about double that!
Does that seem expensive to anyone else? Fiat claim it will take 4.5hrs labour which i'm guessing is the major part of the cost!
Where is the best place to get parts?
If I can't get it sorted cheap then this really is the end for my Seicento which to be honest I really will not miss!
Black Siecento body parts WANTED See HERE
Ross1979 is offline Reply With Quote Quote
Old 17-08-2007   #2
Formerly mog1571
Luke M's Avatar
Trader Rating: 2
Luke M has donated!
Re: Another fault!!!
handbrake will have seized because of the linkages in the drums. 15 quid from fiat and an hour of your time to swap.
as for brake lines. there is cheaper places out there. have a shop around.
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline Reply With Quote Quote
Old 17-08-2007   #3
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
well 1st of all,dealer labour is always expensive so a small garage will be cheaper.
hard to comment on prices when you cant remember the proposed work
Old 17-08-2007   #4
500 quid, they are avin a laugh. go to a backstreet garage or two and get some quotes.
Quote:
Originally Posted by chrisxr2
Looks like a nice pair of puppies, also you have eyes that allude to you being filth (In a nice way) very hard to judge boobs without a nipple though. I would definately do you sober.
chrisxr2 is offline Reply With Quote Quote
Old 17-08-2007   #5
I will have replaced the whole car by the time I'm done lol
£65 just for them to look at it and tell me what was wrong! Getting it towed home tomorrow for £20. I might just flog it to someone that is after an abarth bodykit, interior, rims etc... engine has only done 40k but i have really had enough of it now!
Old 17-08-2007   #6
Civic type-r Driver
Tabblink182 has donated!
if u really want to seel it, the best bet is to break it....
but im sure u could get it working again for less than 500
seems abit steep
Tabblink182 is offline Reply With Quote Quote
Old 17-08-2007   #7
Fehler in alle Teilen
Fivehundred's Avatar
Fivehundred has donated!
Re-plumbing the brakes is no biggy, the actual pipe is cheap, it's mainly a bit of labour. Where in the world are you?
Fivehundred is offline Reply With Quote Quote
Old 17-08-2007   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
I'm guessing somewhere round the M25 in the afluent south east. That will be why the labour rate is so high.
D
Old 17-08-2007   #9
I'm in Brighton, the garage that quoted me was PDH in hassocks.
Old 18-08-2007   #10
kritip's Avatar
Trader Rating: 4
kritip has donated!
there have been several FIAT recall's on brake line corrosion. None for the Sei, but it may be worth asking the dealer to photograph it, and speak to FIAT UK. It may be done under good will. If they are unwilling, speak to FIAT UK yourself. Explain the severity of the situation, and that it lucky you survived. Put on a big sad sob story and highlight the dangers.
Being by the sea it may be just general corrosion however, in which case you'll have to bite the bullet, but as others say, go to a non-dealer.
Alternativly you can do it DIY and save a lot of money. I reccommend copper lines so you avoid any future corrosion. Think you can get them.
Good luck, and heres hoping nothing else goes wrong!
Kristian
kritip is offline Reply With Quote Quote
Old 18-08-2007   #11
Trader Rating: 2
col7104 has donated!
Reference : R/2000/117
Manufacturer Ref : 4089
Make: FIAT
Model : Seicento
Launch Date : 07/12/2000
Numbers Involved : 1084
Build Start Date : 01/01/1998
Build End Date : 31/12/1999
Concern : POSSIBLE CHAFING OF BRAKE PIPES.
Description : Possible chafing of front rigid brake pipes at near side front against the plastic wheel arch liner or against the gearbox mounting. Also at the off side front against the engine timing belt cover.
Remedial Action : Reposition any chafing brake pipe to comply with the manufacturer's prescribed clearance between adjacent parts. Renew any brake pipe that has been chafed beyond a serviceable condition.
Vehicle Id : ZFA187000000001 to ZFA18700000192967
col7104 is offline Reply With Quote Quote
Old 18-08-2007   #12
what exactly is the post above? some sort of fiat recal? My car is an S reg which puts it inside the dates above. It is also strange that it mentions the timing belt cover as that is one of the things that fiat replaced when it went it for repair last month.
Old 18-08-2007   #13
Just found that same info on AA site, cheers. Also my car is one of the ones that could be affected. I'll take that up with them
Old 18-08-2007   #14
Trader Rating: 2
Yes it's a recall. Check it with your chassis number to be sure, its located on the bootfloor. Defo worth bringing up with them, even if its out of the those ranges. They can also check on their systems which recalls have been completed, using your number plate.
Old 18-08-2007   #15
custard's Avatar
Trader Rating: 1
Quote Originally Posted by Ross1979 View Post
cinq & sei recalls are posted in the FAQ section here on FF
Thread Tools
(G) Engine Fault on Stilo 16v 1.6 Aircon 2003 cazzo_man Stilo 6 24-11-2009 08:55
(T) Engine Fault and others smify999 Stilo 12 13-10-2006 18:29
(T) ECU fault / coil braden Stilo 5 29-03-2005 13:14
