This was not supposed to have happened today.
My outlet mounting plate arrived so as it was a chose between working in my shed or getting the bloody lawn mower working.
1/ Place the gasket on the plate.
2/ Mark the sides and hole locations.
3/ Drill and cut.
4/ Make sure the plate fits and mark where the big hole in the middle needs to be.
5/ Use a hole saw to cut a washer the same size as the pipe you'll be using. 6mm took about twenty minutes. Not bad for a shed effort and the average speed on the A52 Brian Clough way this time of year.
6/ Cut the rest of the hole out.
7/ Weld on the pipe and end piece.
8/ Apply a coat of Zinc primer and paint (I've use Aluminium wheel paint as it was the can I grabbed).
My supers are now ready to be charged.
I'm out of budget this month (seriously I'm cycling to work so I have enough petrol for the track Friday).
Shopping list.
1/ Enough ducting to reach the air filter in the bumper.
2/ Front mounted intercooler kit (this will make more sense when it happens).
3/ Exhaust heat wrap for the down pipe and the charger.
4/ Finish the mounting bracket off.
5/ Custom made to length serpentine (auxiliary) belt.
6/ Maybe some bigger injectors if the charger makes more boost than predicted taking my standard ones are over their duty cycle.
