was using this guide: which is the same appraently for the bravo
https://www.fiatforum.com/bravo-brava-marea-guides/81776-marea-20v-gearbox-removal-refitting.html
was following this guide, but it doesnt say when you have to remove the passenger side driveshaft or how to.
do you only need to remove the passenger side drive shaft? when do you do it, and from which end do you undo? do you keep it atacthed to the hub, and undo gearbox side? or do you keep it attatched to the gearbox and undo the hub end?
i cant work it out from the guide, and am at the point where im unbolting the passenger side hub, but not sure what to do with the driveshaft.
