Technical Check with old OBD
NickBr
I have a Brava 100 16v, which I bought in June 2000. The problem I'm facing is that it doesn't have OBD but the older three-pin system.
So there are three connectors in the engine compartment, one for the ABS, one for the ignition and one for the air conditioning, inside the car there is another one .
This has the effect of not being able to check various components and not being able to read errors.
Also in the event that I need to change the throttle for example, I will not be able to set up the new one.
Are you facing the same problem?
I also can't find spare parts any more, and I don't mean after market spare parts, but spare parts specially made for this car.
How do you find spare parts? Even if these are used;
