FIAT Auto Specialist Team
Thread Tools
Old 24-05-2017   #1
tristkm has donated!
squeak from the front
hi all, noticed a squeak from the front end whilst the steering was on full lock a few months ago, maybe happened a few times then stopped, so i ignored it.
Past two days, as I've come to park up at home, the squeak is back. Not even when I'm braking, just rolling. I've had a little look elsewhere but that involved brembo brake pads etc, this is just standard 145bhp.
Has this happened to anyone else? Its fairly loud as well.
Thank you
tristkm is offline Reply With Quote Quote
Old 26-05-2017   #2
p6baseunit has donated!
p6baseunit is an honorary friend of the forum :)
Spain
Re: squeak from the front
Drop links?
Is the squeak there when you rock the car with the handbrake off? Or slow forward movement and steering?
p6baseunit is offline Reply With Quote Quote
Old 26-05-2017   #3
Electric power steering?
jackwhoo is offline Reply With Quote Quote
Old 26-05-2017   #4
It's always more involved
John202020 has donated!
Does the squeak go away when you press the brake pedal? If yes it's probably the front pads, remove them clean everything and make sure they're a "loose" fit in the caliper bracket ie you don't have to hammer in/out.
John202020 is offline Reply With Quote Quote
Old 30-05-2017   #5
hi, no its slow moving, 15mph and below. 95% of the time its happens after its been driven, so I'm assuming sticky pads or something like that. The car is only 6 months old with 4k on the clock. Noticed today under hard braking the car pulled fairly dramatically to the left ( where I've noticed the squeak ). Ironically the sales lady rung me today asking how everything is, might as well give it back to them to see if they can do something with it. Didn't expect to be having problems this early on tbh
Old 02-07-2017   #6
They had it back and changed the brake pads which seemed to have worked for a week and now it's doing it again. 7 month old car and it's starting to have more issues than my 15 year old pinto hgt. Not happy
Old 02-07-2017   #7
Moderator
Quote Originally Posted by tristkm View Post
Read this, and look at the pretty pictures.
Classic symptoms of the pads sticking in the reaction frames. Clean and reassemble (or fit new pads), and they'll be fine for a week or two, then start sticking again. Clean. lubricate properly and reassemble, and they'll be fine for the life of the pads.
It's tempting to start bashing Fiat at this point, but in truth I'm struggling to think of a car I've bought in the last thirty years that hasn't suffered from this issue. The technique I describe in the linked thread has resulted in a complete fix in every case.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 02-07-2017   #8
If it's pulling one way or other it's dangerous and needs to go straight back immediately to be fixed.
Ask garage to put it on a brake roller tester and write down the results in brake effort side to side.
Old 02-07-2017   #9
Il show them this post. I'm not touching it in case they decide to invalidate the warranty. Pretty poor tbh
Old 02-07-2017   #10
Yes don't touch it yourself for reasons you gave and also why the heck should you.
If garage doesn't have a roller brake tester, if the do MOT tests they have to have one, show them it pulls to side under braking.
Old 02-07-2017   #11
Yes this is desira in Norwich/Norfolk. Also one bit of the side skirt was coming away from the car so they put some more glue or whatever it is and it's come away again. So they said it'd have to go back to body shop to be done properly. Just lots of ****ty bits really. It will have gone back for the 3rd time within a month.
Old 02-07-2017   #12
That's crazy it should have been done properly the first time.
Find out what your rights are regarding rejecting the car as unfit for purpose, mention your rights when you go back. Plus make sure they write down on records you feel brakes are dangerously pulling on one side.
Or print out a note saying the above, make two copies. One for them to keep and one for them to sign and date and give back to you .
That will make them think a little harder.
Old 14-07-2017   #13
Canada
I`d also guess for transmission
Glooby is offline Reply With Quote Quote
Thread Tools
(G) Squeak from front suspension - any ideas? Cadabena Grande Punto 4 22-08-2014 19:03
(G) Squeak squeak dombooth Grande Punto 8 07-02-2013 16:08
(G) squeak from front wheels seanrich0585 Punto (Mk2/2b) 3 03-01-2013 18:24
(T) Squeak from front right? Scooby[OCuk] Grande Punto 3 05-06-2008 22:41
Squeak from front wheel... Colm Moroney FIAT Boo Archives 3 08-10-2000 15:49
