turbo500
Member
- Mar 20, 2013
- 251
- 118
So my signorina finally arrived, but as soon as I start it, the idle seems way too high.
When I checked it at the mechanic, it was running fine, but it seems something happened during shipping.
I've attached some photos, maybe there's something I'm missing.
The throttle butterfly screw (A) is completely unscrewed, while screw (B) for mixture is as is. I tried turning it 1 rotation both directions but it didn't seem to do anything. I also didn't want to screw up anything.
Someone suggested to check if the choke cable is catching somewhere? How would I check that it's effectively 'down' on the engine side?
Also how would I remove the hand throttle cable to eliminate that as a factor?
Thanks in advance!
Thanks in advance!
