Thread Tools
Old 2 Weeks Ago   #1
Italy
Drip, Drip, Drip
Well, I took the old 69 Lusso down to the parts shop here in Italy and found an old fella who was a mechanic. I have a very limited understanding of Italian at this early point in my stay here! He took the 500L to his shop and changed out the clutch and rebuilt the brakes with new parts that I paid for at the parts store. The clutch was much smoother engaging than it had been. But coming up the hill to my house a week later it locked up in 2nd gear. I was finally able to get it functional again and got home, but while parked it was leaking transmission/clutch box fluid! It finally stopped leaking after about a day. I have spare fluid but have no idea where to check the fluid level or add additional fluid to get it back down the hill to the mechanic who worked on it! Can anyone point me in the right direction as to checking the current level of fluid and adding more if required? Thanks Eric
EricJan is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
Re: Drip, Drip, Drip
The clutch on the 500 is cable operated, so no leak from there. If you do have a gearbox leak, the chance that ALL the oil has leaked out is slim, so if the garage is only 2-3kms away you should be able to drive it gently to the garage with no problem. Filling the gearbox is very awkward unless you either put the car on stands at the rear (NEVER, NEVER work under a jack) or on a ramp as the filler/level plug is on the right side of the gearbox, between the bell-housing and the drive-shaft and normally VERY tight. The gear-box is filled through the filler plug until oil comes out of it--level then correct.
the hobbler is offline Reply With Quote Quote
Old 2 Weeks Ago   #3
Italy
Thanks very much Hobbler. I'm very new t this, but figured if I can rebuild RV's I can figure the out! If you don't mind I'll let you know how it goes!
Old 2 Weeks Ago   #4
USA
Where are you at in Italy?
Luxe is offline Reply With Quote Quote
Thread Tools
(T) Oil drip drip drip yvesthepunto Punto (Mk2/2b) 2 11-03-2011 13:38
(T) Aircon Drip kingchris Stilo 3 29-06-2006 17:54
(T) Leaky engine.. drip drip :( arc Cinquecento / Seicento 8 23-06-2005 00:25
(T) Water drip Graham Lane Stilo 9 23-08-2004 17:36
drip..... MG FIAT Boo Archives 1 11-02-2004 16:04
