Thread Tools
Old 12-06-2017   #1
marcus550 has donated!
USA
Wheel balancing in the U.S.?
Anyone had their wheels balanced in the U.S.? Just moved to North Carolina and the weather here should allow me year-round driving enjoyment. I know this sounds odd, but the little Fiat starts to vibrate at 60 MPH. It will do 70-75 here on the flat roads but the vibration is worrying.
I just replaced the upper control arms, bushings and shocks. One upper arm bolt was close to falling off, so it was good timing. Fixed the loose steering feel but now this vibration is apparent. I don't see any weights on the wheels so they're likely not balanced.
Is there an adapter plate to be purchased? Or plans for one if I have to have it machined up?
Mark
1970 Fiat 500L 'Lusso'
1998 Beck 550 Spyder
1991 Nissan Figaro
2015 Mini Cooper S
marcus550 is offline Reply With Quote Quote
Old 12-06-2017   #2
stevehg has donated!
Re: Wheel balancing in the U.S.?
No adapter plate needed by you, you just need to find a shop that can mount the wheel by the stud holes on their balancing machine. Usually, they'll have an adapter to do this.
stevehg is offline Reply With Quote Quote
Old 12-06-2017   #3
I forgot to add, if you can't find a tire shop that can balance them, and you're running tubeless tires, you can use balancing beads.
I've used these on aggressive off road tires that are a nightmare to balance, and they work as described.
Cheers, Steve
Old 12-06-2017   #4
USA
I would also get a front end alignment. That may also be the cause of your vibration. I would think any tire shop should be able to balance your wheel/tire.
John
1969 Fiat 500L
jjacob is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
USA
OK, two tire shops in town could not balance these wheels. Their machine requires mounting through the middle of the wheel and my Fiat 500L wheels have a metal strap welded across this opening to mount the hub cap to. So...now what? Both said they've never seen a machine that could do it. One worked in a motorcycle shop as well and said their machine wouldn't work either.
Has anyone actually had their wheels balanced? Balancing by the studs doesn't sound reasonable (if I could find someone to do it.) The wheel is hub-centric, not bolt-centric. My VW-based Porsche replica uses wheel bolt-centric wheels and they have special conical bolts and socket-shaped indents in the wheels to center the wheel. The Fiat has no such thing. It centers on the cast wheel hub.
1991 Nissan Figaro
2015 Mini Cooper S
Old 3 Weeks Ago   #6
I find this a bit disturbing in the the good old USofA in your part of the country that you can't find a suitable garage to do this. I'd be asking around senior mechanical/engineer background people if they can come up with any suggestions. I'm old school & remember those portable balancing stands, where you put the wheel on top with the level. These were very acurate by the way.
Best of luck.
jimboy is offline Reply With Quote Quote
Old 3 Weeks Ago   #7
I had mine balanced and as suggested by Steve they used an adaptor plate that had studs on it that went through the wheel nut holes. They had issues at first because they couldn't find an adaptor plate with the correct PCD for the little wheels. But these guys were really determined to find a way to balance them. They managed eventually to secure the wheel centrally to their machine but it took a little engineering on their behalf to do it.
Vitesse is offline Reply With Quote Quote
Old 3 Weeks Ago   #8
USA
Hi Marcus550,
The problem of not finding any places that can balance the 500's wheels is becoming an issue also in Italy unfortunately. There are always fewer places that have the correct adapter or an on-wheel balancer.
You need to find someone who has the adapter, or better yet, the on-wheel balancer (saddle style). This means that wheels stay on the car and the balancer rotates the wheel.
Here are some other car owners with a similar issue:
https://www.thesamba.com/vw/forum/ar...-409914--.html
https://www.jalopyjournal.com/forum/...r-hole.375655/
I think this comment will be especially useful:
"take it to a walmart tire center and tell them to use the plate with the "fingers" I work at one myself and have used it many times before. If you know your bolt circle it will be helpful. "
turbo500 is offline Reply With Quote Quote
Old 2 Weeks Ago   #9
Australia
No need to balance them. Never seen 500s with wheel weights to to the tiny size of their wheels.
OO==/////==OO
124CS, 500F, GRANDE PUNTO, BRAVO T-JET
124spiderman is offline Reply With Quote Quote
Old 2 Weeks Ago   #10
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by marcus550 View Post
So who balances the Porsche wheels? They can do the 500 wheels too. This is not just a problem for classics. My Croma (GM / Saab / Fiat design) has alloy wheels with centre holes but they are not machined or accurately located, just cast to clear the drive shaft nut cover. They fit on a centre mount balancer but it's hit or miss if they balance correctly, Use of centre hole balancers ids just because they are easier/cheaper to make.
Robert G8rPI.
g8rpi is online now Reply With Quote Quote
Thread Tools
(T) Wheel balancing or something more sinister? Mr Mayoh Grande Punto 3 18-01-2013 18:08
(G) wheel balancing weights Fiatpuntomk2b Punto (Mk2/2b) 7 04-09-2011 18:46
(G) Wheel balancing or tracking??? AY786 Punto (Mk2/2b) 7 15-06-2008 15:13
(G) Wheel balancing black_cinq Cinquecento / Seicento 17 14-09-2004 21:42
Wheel balancing and tracking smurfhead Lets Talk FIAT 6 20-09-2003 03:43
