- Hi , i recently bought a fiat uno 1.0ie 1997 . Can someone tell me is it possible to connect my car with some OBD conector to resolve problems with sensors for example ? Thanks in advance !
Hi there
These first unos have a very basic electronic injection. This guide may help:
https://www.fiatforum.com/cinquecento-seicento-guides/238241-reading-spi-ecu-data-logging.html although I am not sure that software works for the Uno. I was looking for a post here on fiatforum where someone came up with a DIY code reader gizmo made up with a LED. The procedure was to bridge two of the three pins and the LED would flash a number of times depending on the error. Sadly couldn't find it.
However there's a troubleshooting post here: https://www.fiatforum.com/uno/27621-uno-999-fire-ie-erratic-idle-warm-up-bosch-spi.html and have a look at post #10 .
I think it may give you some better help than an ECU reader.
I hope this helps
Afonso
