| 3rd Gear Spins Anyone? | tuning mods for fiat uno turbo mk2 alright people, as u know i've got a mk2 uno turbo but i'm wanting to know what to do to it next! i already have:- scorpion exhaust HUGE volvo FMIC induction kit dump valve samco hoses polished/ported/skimmed head lightened/balanced flywheel slightly larger pistons uprated spreso rasing head gasket bleed valve (set between 16psi upto 22psi) fse boost valve spitfire leads and plugs abarth steel billet cam piper vernier pulley piper cam belt black diamond uprated clutch uprated fuel pump T2/T25 hybrid turbo slightly lower compression and probbably some other bits, but what do i do next? can the 1.6 bottom end from a punto sporting be mated to the engine? also thinking of a T3 hybrid turbo, better management with a chip, anti-lag, 5th injector, ap racing paddle clutch, bigger forged pistons (cosworth or simlar) and bigger injectors (cosworth). do u think all this will run together? i'll be running about 30psi of boost. help needed as i was a totally rapid uno turbo running about 250bhp cheers Dunc
__________________ Uno Turbo i.e Uno 1.0 (Will be given a turbo lump soon) Fabia VRS S14a 200sx - R.I.P | ||
| | #2 | |||
| Back once again w'the... | Re: tuning mods for fiat uno turbo mk2 OK, well you can build up a 1580cc motor using the Tipo 1.6 motor as a base. You will need to do something about the fuelling, though. Have you done all this work yourself... if so I'm impressed... if you haven't, well I'm still impressed ![]() By the way I think we've met in person, I was at Santa Pod in August 2003 when the Turbo Collective boys organised a 'meet' there. I was driving a rented silver Punto. -Alex
| | #3 | ||
| Re: tuning mods for fiat uno turbo mk2 I would do the following: bigger turbo that can handle alot of boost. Aftermarket ecu and bigger injectors. And of course a better clutch.. Boost ~2 bar and you should be near 250 hp according of camspesc. I have worned out two 3-paddle copperclutches with uprated pressureplates. Now I have a aluminum AP clutch, can handle 620 Nm.
__________________ Fiat coupe 20v turbo ![]() Fiat uno 355 hp Fiat x1/9 (with 1.3 l turbo) Fiat x1/9 (soon with 2.0l 16v turbo) Last edited by uno_jens.; 09-12-2004 at 19:05. | |||
| | #4 | |||
| Funny saying here | Re: tuning mods for fiat uno turbo mk2 Some form of Aquamist? That's a lot of goodies you've done.... Anything else is gonna be really silly money i would expect!
| | #5 | ||
| 3rd Gear Spins Anyone? | Re: tuning mods for fiat uno turbo mk2 cheers people ![]() yeah i was thinking of aquamist too mate. should be pushing out some proper stupid power when done goin for the most powerful/quickest uno turbo in the uk (hopefully)Dunc
| | #6 | ||
| Re: tuning mods for fiat uno turbo mk2 Why aquamist? water/meth injection in my opinion is a last option.. + lowers your charge temp : better with a high efficient intercooler. - have to fill the extra tank - If you tune your car with waterinjection engine can predetonate if you run out of water/meth. - build higher backpressure with water/meth. Don´t you have E85 in uk? The best would be to tune your car on E85, you need ~30% more E85 than premium. So big injectors and a aftermarket ecu would do the job... I am going to run my uno on 1008cc @3 bar injectors..
__________________ Fiat coupe 20v turbo ![]() Fiat uno 355 hp Fiat x1/9 (with 1.3 l turbo) Fiat x1/9 (soon with 2.0l 16v turbo) | |||
| | 1986Uno45S | Uno | 31 | 01-03-2008 09:58 |
| uno turbo brakes on a 128... | onetwentyeight | Lets Talk FIAT | 0 | 14-09-2004 00:28 |
| | Slinkylinks | Uno | 4 | 11-05-2004 11:25 |
| Will Uno Turbo seats fit in my panda | Surrey Sporting | Panda (Classic) | 1 | 12-12-2002 22:47 |
| | Surrey Sporting | Uno | 0 | 26-10-2002 17:39 |
