If the car is indeed going to be used for rallying then there may be a restriction on engine size for the class it was built for. Therefore the 1.0 litre engine may have to stay. Also, entry level rally classes often ban the use of turbos so the 1.3/ 1/4 turbo engines are out.
Also, the FIRE is NOT a crap engine Jug. That's a very flippant remark to make about what is quite a groundbreaking and very strong engine. The basic design of the 1.3/ 1.4 Turbo engines are MUCH older (they were designed in the late 60's and saw use in the first 128) and they are considerably heavier plus have 30% more moving parts. On the track/ stage weight is a handicap in terms of performance and handling so there are big advantages to using the FIRE lump instead.
For tuning a 1.0 FIRE i.e. the first step should be to fit a 266 camshaft, which I think is the same as a Punto 75 mpi. The original 1.0 litre camshaft is designed for torque and economy and doesn't like to rev. I *think* the cylinder head from a Punto 60 has larger inlet valves so you could look at fitting one of those. Then look at fitting a larger throttle body, maybe from a Cinq Sporting or Punto 55/ 60.
Other than that you'll need to look at improving the induction and exhaust systems. A good session on the rolling road will help to point you in the right direction and/ or tweak any mods you've already done. And don't forget that Oldschool has had a lot of experience with tuning FIRE engines so contact him if you want reputable work done.
Oh, and I take it you've bough that white mk2 rally Uno that was on Ebay recently? If you did, it used to belong to a member on here called SuperUno!
