The FIAT Forum
Old 12-03-2008   #1
YTUNO's Avatar
Trader Rating: (0)
New Zealand
Rear Disk Brake Conversion
I have purchased new callipers and disks for the front of my MK1 Uno and I am now wondering whether I replace the rear drums with my old front disks and callipers. Does anyone know if this is possible and what is required?
YTUNO is offline
Old 12-03-2008   #2
Trader Rating: (0)
Re: Rear Disk Brake Conversion
if you did that youd have no handbrake mate unless you did a custom one or hydraullic
waynegts is offline
The following user says "Thank You!" to waynegts for this useful post:
YTUNO (12-03-2008)
Old 12-03-2008   #3
Trader Rating: (1)
as soon as you pressed the brakes the car would do a 180 ha ha!!
antsuno2 is offline
The following user says "Thank You!" to antsuno2 for this useful post:
YTUNO (12-03-2008)
Old 12-03-2008   #4
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
Front discs/ calipers would be too powerful for the rear of a Uno. There's a bias proportioning valve but they always seize up, so the last thing you want is more poweful rears. As Ant says, you'll stamp on the brakes and the rear of the car will overtake the front!
The biggest advantage of rear discs is a reduced risk of brake fade. However, do you really drive your car that hard to promote brake fade in the rear? If it's not a turbo, probably not. Plus don't forget that the fronts do 80% of the work anyway.
If you really want rear disc brakes then you'll need to source a Uno Turbo rear beam that comes with rear discs as standard. You cannot bolt on rear discs/ calipers onto a brake drum rear beam, or at least not without a LOT of work. Even if you managed that you'll still have to sort out a handbrake.
Give your rear drums an overhaul (new shoes and cylinders - cheaper than a rear discs conversion!) and you might be very surprised at how good they can be. The reason rear drums often aren't very good is because they haven't been serviced for years...
Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
1986Uno45S is offline
The following user says "Thank You!" to 1986Uno45S for this useful post:
YTUNO (12-03-2008)
Old 12-03-2008   #5
YTUNO's Avatar
Trader Rating: (0)
New Zealand
Hmmm, 180s at every intersection could get rather tiresome I guess .
The only reason I am thinking of going to rear disks is for trials use which tends to be a bit hard on the handbrake. I'll referb the rear drums and see how we get on. I have access to a Turbo rear end if I need it, but that sounds like it could be an option of last resort.
Thanks guys!
YTUNO is offline
(T) Discussion Thread: Brake Light Switch Replacement Deckchair5 Stilo 42 17 Hours Ago 09:24
(T) Cinq Strange Rear Brake Problem Cinqster355 Cinquecento / Seicento 15 30-12-2006 23:57
(T) Rear brake light not working badkilla Stilo 19 08-11-2006 01:00
(T) HGT Rear brake piston EvilJaxx Punto 2 24-09-2006 00:33
Help - rear brake self adjuster needed (RH) palicus Tipo 1 21-09-2006 23:15
