Hi Guys,
my 20v Marea has decided that it will refuse to idle or rev after having its cam belt changed.
What happened is this - followed Pete's guide & marked everything up, realised that in order to change the idlers and tensioner I'd have to shove the engine over a bit so took it off its mounts and pushed it right over toward the nearside. Changed the tensioner (for a nice spangly cast alloy one), idler and new belt. Fired her up & immediatly sounded like a bag of spanners. Ran onto fast idle for 2-3 sec then drops to slow idle & stalls. Try revving & get nasty backfire. Wont go above 3000rpm
Immediatly suspect timing, so pick up set of cam locks. Lock cams & follow FIAT procedure, re-fitting belt & slackening off pulleys to set timing using locks. Fire her up - exactly the same.
I have my suspicions its a sensor issue. Possiblly the cam position unit, or perhaps the MAP sensor.
Its a 99V with the 155bhp lump & fully electronic throttle.
Any ideas?
Any ideas?
