G
George
Hi
My driver side wing mirror got whacked the other day. The glass has fallen out and is badly cracked and slightly bent. It's dangling by a couple of wires, I presume for the heating element.
The electrics still work fine so I presume I just need to replace the mirror itself and stick it back in?
Can I just pull off the broken glass and stick a new mirror on or do I need an actual mirror, remove wiring off existing mirror and add to new one (can't see how it's attached at present?).
If the former, what should I use as adhesive to stick the mirror back into the housings.
Many thanks
G
A very happy Bravo owner, 15yrs and 110K+ on the clock from new and apart from the usual niggles, it's been without fault.
Many thanks
G
