Punto 2012+ Window winder spindle different size
Andy mcguire
Hi all I changed the window regulator on my 2014 Punto as it said on the eBay advert that it fit my model reg went in easily enough however the spindle the handle fits on is wider has anyone come across this before and if so what handle did you get as a replacement.
Thanks in advance
I've messaged him just waiting for a response so Corsa or the MiTo also fit ?
Thanks for responding pal I know it's a boring thread ?
Much appreciated
Thanks again pal what year corsas should I check same year as the Punto?
Thanks again pal ?
Thanks mate I will check when I go round some scrapyards thanks again for your help pal I'll let you know the outcome ?
Hi mate I trawled scrapyards today pulled off handles from Corsa d all manor of fiats from all years older and newer from pandas to Evo stilo Punto Grande Punto so ended up buying a used mech and will return the eBay one thanks again for your help
