I don't quite get why people are getting so worked up about this, this is little different to how a conventional torque converter automatic would work. In neutral at the lights facing uphill (you shouldn't leave it in drive and hold it on the brakes for any longer than a second or two) you'd have to have the brakes on to stop yourself from rolling back.
I was never a great fan of hillstarts myself, I did my lessons in a manual and my test in a manual, but for the first 6 years of my driving life, I'd driven automatics and I'll be honest, when I moved to the UK and had to start driving on some quite steep and narrow roads (compared to what now seem like runways fit for a 747 back in Australia) it was a little bit of a worry. The act of using three pedals and the handbrake in such a short amount of time takes a lot of co-ordination and if you've not done it, then it's hard. For these reasons I understand why people go for automatics, I really do.... Hell, if I could have got the hill holder without speccing ESP then I would have.
But getting back to the dualogic. Here we've eliminated the clutch pedal from the equation and in simple terms you have a stop and a go pedal and because there's no clutch, there's no need to use the handbrake as you would have to do in a manual. It really is as simple as that. Stopped on a hill? Press the brake pedal to hold yourself, pop it into first whilst holding the brake pedal and gently accelerate away and release the brake pedal.
Not to be rude, but if you can't manage that low level of co-ordination then you have to question whether someone should be driving. That's easy, there are far harder things you'll have to do, today the traffic stopped on the dual carriageway and I had to manage to brake hard enough to not crash into a co-worker in his BNW 500 lounge whilst not braking so hard that the numbnut in a BMW 325d with Raybans on doing well over the speed limit would go into the back of me.
S&S, dualogic and the hillholder are three things which unfortunately conflict somewhat, tbh Fiat should not have included the hill holder on the dualogic S&S models and this issue simply would not be one that people could complain about. It's kind of like selling a chocolate fireguard, it's never going to successfully be a fireguard and be chocolate at the same time.......
P.S Kieron, if you want to dislike this post then feel free to, it does absolutely nothing unless 4 other small minded people join you, in which case this post will be hidden
