Very vaguely... if you look under the car, just inboard of the sills near the markers for the standard jacking point (these are marked on the sills by two indents on the sill itself, one behind each front wheel and one infront of each rear wheel), you can see a hole in the chassis where car lift arms locate. I use this area for placing the axle stand - I figure that if it's good enough for the the lift, it'll be good enough for an axle stand.
