tarquin1867
Anyone found any problems with front wheel bearings yet?Mines seems to have developed a droining sound from the front?Its now just turned 70k.
Diagnosis is 8/10ths of the job done. Check if its speed related and if its specific to one side or the other, I know its obvious but if its speed related and not worse/better on corners check the level of oil in the diff. I had a Renault 19 diesel that this happened to.
If it is the front bearing make sure you don`t move the plastic cage on the bearing or the ABS will be compromised and loads of other faults will show up on EOBD:bang:
