Like koalar, I've nearly always used a large socket. In the garage workshop we had a dedicated installation kit but often it was quicker to just use a socket. If the seal isn't in a recessed housing I've even done it with a small hammer but the risk of distorting the seal is high. One of the biggest things is to keep it going in absolutely "square on" to the hole which is much easier to do with a socket.
Take it "easy" and tap it in just a wee bit with each stroke of the hammer and, as koalar mentions above, as soon as you notice it's not absolutely square with the hole then tap it more on the side which is standing proud.
Just a thought for the future - are you developing a "relationship" with your local factor? Ours has a selection of timing and specialist tools which are for hire to "the trade" If you regularly buy stuff from them you may find they will be amenable to letting you hire these tools, mine does once you become a "weel kent face"
