- Joined
- May 5, 2006
- Messages
- 894
- Points
- 214
Did some searching on the forum but couldn't find an answer to this problem:
i changed the instrument cluster in my 1.6 Stilo (2002) by a colour display instrument cluster from a 2001/2002 Abarth.
Used my Examiner to do the cluster replacement procedure and did a Proxy alignment procedure to align it's programming to my body computer.
Everything works fine up to one "little" problem:
When I turn the ignition or start the car the pointer of the water temperature gauge goes to max. for 4-5 seconds, the warning beeps sound, the red warning lamp lights up (but I guess it always lights up during the check period?)
After this the pointer returns to it's normal position, beeping stops and red warning lamp extinguishes - everything works as expected after these 5 seconds....
No fault codes are stored in any node concerned- I also tried if any software updates existed on the Flash cd but no result.
Does anyone know how this little annoyance can be cured?
During my search on the forum i encountered several issues mentioning the same kind of problem but i didn't find a solution yet...
I hope somebody knows how to fix this....
thank you,
yellowstilo
thank you,
yellowstilo
