General Water leak in the cab
Edwin57
Shropshire
Hi, After three days of heavy rainfall, I found a small puddle of water in the gear lever gater. Not sure where it's getting in. Any ideas ?
I removed the interior cab light and its dry there. It's either coming in through the arial fitting or the windscreen.
Any one else found this ?
Regards
Ed
Just joined and had exactly the same problem with mine and so stripped out the headlining and found the leak coming from the passenger side top corner of the windscreen where the outside seam joins the windscreen. At the moment I just pushed some putty in but as I need to replace the windscreen anyway I'll wait till then.
The water ran all the way from that corner until it emptied out through the interior light into the gear lever well.
