Technical water/coolant leak
Fiatrick
noticed when changing coolant on the bravo 2.0 20v, that it was leaking, seems to be from top of the engine from the pipe running behind the exhaust manifold. its dripping on the engines right side ( by cambelt) can see Water run behind the alternator. are there any gaskets ?
sorry, for bad English.
Is it the aluminum pipe that goes the width across the cylinder head. If so then yes. There is a steel shim gasket.
alright. will have a look at it. is it a commonplace for a leak on the 20v's ?
have changed the gasket between the pipe and the engine today. but there is still some coolant dripping from around there.
any chance it could be water pump ?(it have been changed with cambelt a few weeks ago. har havent been started since bel t change.
