Pat H
Notcied the front washers had been playing up recently. Worked sometime not others. Better if the washer bottle full.
Then realised that using the rear wash caused the next go of the front to work.
Remembered that many new cars use the same pump and washer bottle for front and back by powering the pump in one direction or the other.
So suspect using the rear gives the worn pump a kick so it works forwards.
So ordered a pattern pump from shop4parts £22 including delivery.
Now the question:
What's the best way to change it?
I can see it down by the stearing fluid pump but looks almost impossible top access! Maybe from below? or take out the iner wing plastic and remove the bottle?
Open to thoughts.
Now the question:
Open to thoughts.
