i'm in the process of changing my vl37 to a vl38 and was wondering what the best way to go about it is?
i've stripped away all the heat shields so i can get a better look at the turbo and manifold... is it a case of replacing the WHOLE unit...turbo and manifold connections? or can i simply get away by uncoupling the turbine from the manifold and sliding it inside the old one?
seems like its gonna be a HUGE job if i'm replacing the whole thing.
i understand the manifold/exhaust sections are the same on both and it is just the turbine shaft that's different and the inside geometry of the actual turbo...?
