kkemerait
Last night I rebuilt my weber 32 ADFA on a 1978 124 Spider. I am NOT a mechanic and while I followed the instructions carefully, I certainly could have screwed something up.
Symptoms:
1. Very rough Idle
2. Dies after 2 or 3 minutes
3. Takes 5-10 sec, for timing to return to base after accelerating (normal?)
4. Very long lag when pushing on accelerator before car actually has any power..can stall on small hill then all of sudden gets big burst of power (after hold down accelerator for maybe 15-20 seconds)..after that seems ok
Current Settings:
1. Timing 4 degrees BTDC
2. RPM 900
3. Dwell 52
4. Main Jets (125/140) (no change from original)
5. Air (170/185) (no change from original)
6. Venturi (3.5/3.5) (no change from original)
Any diagnostic help would be greatly appreciated, I'd even be glad to record the engine sounds or take photos if needed. Thanks again!
			Symptoms:
1. Very rough Idle
Current Settings:
2. RPM 900
3. Dwell 52
