Technical Tricky diagnosis
Joe10123
Kent
Hi all,
I’m stuck with my punto evo car runs and drives lovely but intermittently struggles to start.
Engine light is on permanently and I get engine code p0069-62 which is map sensor, so I have changed the map sensor and still get the same fault code come up?
Also had engine codes p0512-12 starter motor signal, u0426-63 immobiliser circuit and u0001-88 engine control module. If I leave the ignition on it then tells me that ABS is unavailable start stop is unavailable Hill stop is unavailable ect…
I’ve checked all connections can’t see any visible issues battery is all working as it should. Has anyone had anything like this before advice would be greatly appreciated
